installing a electric fan to a toggle switch
Discussion in 'Technical' started by lynhrt210, Mar 13, 2010.
  1. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Ok so I got my electric fan on my radiator now can somebody please tell me how to wire it to a toggle switch so that I can turn it on whenever I want please thanks!! :)
  2. Bubba Bob
    Bubba Bob Member
    Auburn, AL
  3. 71gold
    what fan did you go with?
  4. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Umm all I have so far is a toggle switch and the gauge wire 12', and its a flex-a-lite syclone. Thehighest cfm one
  5. 71gold
    (y)..the only thing i can add to Bubba Bob, is...an inline fuse ...
    Frank
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    why do you want a toggle switch?
  7. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Idk I just thought it be cool to have one to turn it on and off anytime I want and does anybody have pics of how to do this.
  8. 71gold
    i would suggest a...lighted toggle/rocker switch...that way you will know when it has power going to the fan...:yup:
    ...:bouncy:...
  9. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    Yeah that's what I got already that's lights up blue with my interior but how will I get it too light up to show its on?? I really have no idea to connect any of this:/ teach me mastas!!! Haha
  10. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    First - What is the primary source of control for this fan? Do you have a temp probe or some other automatic means of controlling the fan, or is the toggle switch going to be the primary? If so, what are you using for a temp guage? Is it accurate enough?
    Anyhow, back to the switch, relay, and in line fuse (all three of which you will need). These are all pretty universal installs, so a search of google will yield some detailed DIY guides with photos and such. Start with this about relays -
    http://www.mp3car.com/vbulletin/faq-emporium/117895-faq-relays-how-they-work-how-wire-up.html
  11. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    I'm gonna use the temp gauge as for heat and its gonna be the primary for turning it on and off
    Ill read up about it to see to configure it some how haha
  12. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
  13. MSmithPDX
    MSmithPDX Member
    Portland, OR
    really this is not hard at all to set up. you get a single throw relay that reacts to 12vdc power.
    find a stable power source in your dash to hook the rocker switch up to.
    ground the rocker to likely your chassis. run the output of the rocker to the input for the relay throw.
    ground the throw of the relay to your chassis.
    break the power line of the fan and insert the relay pass through into the break in the power line.
    done.
  14. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    Also, Ive heard in setups such as what the OP wants to do, when the power is cut to the fan the fan becomes a generator until it stops spinning. This over time will kill the relay.... So a diode should be place between the fan and relay.
    Thoughts folks?
  15. MSmithPDX
    MSmithPDX Member
    Portland, OR
    most GOOD relays come with a built in diode. In fact do not buy any relay that does not.
