Installing an oil psi gauge
Discussion in 'Technical' started by BrianB, Feb 18, 2011.
  1. BrianB
    BrianB Member
    1973 Maverick
    ill just make it short.. where do i put it? haha the sensor i mean. i have a 73 302.
  2. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    Stock, or, aftermarket?
  3. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    Sorry bout the double post...
    The sending unit/sensor is mounted between the fuel pump and oil filter, just above the bottom right timing chain cover bolt protrusion on the block.
    Eric
  4. mercgt73
  5. maverick75
    I would suggest using a copper line if it's a mechanical sensor. I've had the nylon ones break, melt, etc... And it's just a mess. Autozone sells a sunpro copper line kit for ten bucks, totally worth it. It also looks better.
  6. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    X 2 on the copper!!
  7. BrianB
    BrianB Member
    1973 Maverick
    so does the oil actually go threw the line? if so do i have to bleed it and get the air out?
  8. Bryant
    yes oil does go into the line but you dont have to bleed it. i am suprised that gage manifactures still put the plastic line in. its a lawsuit waiting to happen.
  9. BrianB
    BrianB Member
    1973 Maverick
    its raining right now so cant put it in but it looks like a major pain to get to that stock sender anyone have any advice?
  10. PaulS
    Use a long nipple to bring the sender out where you can get at it when you install it. There is a socket to get the old sender out.
  11. BrianB
    BrianB Member
    1973 Maverick
    is it called an oil pressure switch socket?
  12. indyman13
    indyman13 Member
    Little Rock, Arkansas
    I ran mine with appropriate adapters for the oil when I put my gauges in so I'd still have the idiot light-----sometimes I turn idiot. Did the same for water temp. ... same reason.
