Installing deluxe gas cap with cable.
Discussion in 'Technical' started by indyman13, Feb 20, 2009.
  1. indyman13
    indyman13 Member
    Little Rock, Arkansas
    I found a deluxe gas cap with cable and mounting stud and want to install on my 73. Could someone post a pic or a good description on how to mount it?
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    woa, woa, woa!! Slow down there speedy gonzalez. So one more time . . . :rofl2:
  3. indyman13
    indyman13 Member
    I'm guessing with the cable laying flush against the rear panel the eyelet it passes through on the back on the cap is supposed to slide easily around the cable? Note I said supposed to. It's binding up therein creating the problem that prompted the post. Easy solution--cable cutters!:rolleyes:
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Make sure the cable is clean. Perhaps a little silicone lube will help as well.
  5. Craig Selvey
    The cable mounts in the 4 o'clock position I believe if memory serves me correctly.
  6. davidjfranz
    davidjfranz Member
    Chicago,Illinois
    1971 Maverick 15,000miles!
    1970 Gas Cap Install
    :thumbs2:Hello, I am also going to install one of these beautiful deluxe gas caps on my 1971. Does the stud go through one of the existing flange screw holes? The nut obviously goes inside the trunk? Thank you.
  7. rickm
    rickm Member
    Owosso Mi
    I just put one on my car and you use the 4 o'clock hole and just screw the bolt on the cable into it, same thread. Bam boom Done Rick
