Installing headlight warning buzzer/chime
Discussion in 'General Maverick/Comet' started by 55crownvic, Sep 14, 2016.
  1. 55crownvic
    55crownvic Member
    colorado springs
    My car does not have a headlight warning buzzer, and I would like to install one. Anyone ever done that? Wonder how hard that would be to do.
  2. 71gold
    I installed one in my car.
    mine may be a little different than most.
    I got another dome light switch and wired a buzzer from radio shack into it going to the parking lights.
    yellow75 likes this.
  3. rthomas771
  4. 55crownvic
    55crownvic Member
    colorado springs
    thanks guys, think I have it figured out.
  5. mojo
  6. 71Mavrk
    71Mavrk Member
    Nevada
  7. 55crownvic
    55crownvic Member
    colorado springs
    Thats a lot of money for me, I'm gonna go this route......... http://www.gmcmhphotos.com/photos/data/5969/test.pdf
    and heres a buzzer on ebay......... http://www.ebay.com/itm/322224093595?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    and his instructions, pretty simple.............
    This is a perfect buzzer for warning you if have left your headlights on when you turn off your ignition key.
    Use a test light to find any wire or fuse that turns on and off with the headlight switch, and then find any wire or fuse that turns on and off with the ignition key. Connect the red wire (+) of the buzzer to the headlight fuse or to any wire that the headlight switch turns on/off, and connect the black wire (-) of the buzzer to any fuse or wire that turns on and off with the key. The buzzer will only sound if the lights are on and the key is off.
    I will be doing mine this way, just attach the wires to two fuses and done, piece of cake.
  8. 55crownvic
    55crownvic Member
    colorado springs
    Got er done, works perfect, was a PITA to reach that POS fuse block tho, can be done.
  9. 71gold
    :thumbs2:...that's the same buzzer I used.
