instrument lights
Discussion in 'Technical' started by mavtricks71, Aug 27, 2004.
  1. mavtricks71
    mavtricks71 Member
    hey everybody i did the upgrade to a 2825 in my instrument cluster, is there a upgrade for the bulb that goes behind heater switch panel?
  2. 71gold
    m t 71,
    congrads. on the upgrade (y). i don't know about a diff. bulb for that. what i did was took the light holder and taped it off and painted the inside with rattle can " chrome "...frank...
  3. mavtricks71
    mavtricks71 Member
    ok
    ok sounds good, thanks
  4. j miller
    Polson, Mt
    who carries the 2825 bulbs? i asked at the local dicount/advanced auto and they looked at me funny.
  5. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Jason, when I did my conversion to the 2825 bulbs I also went to Discount Auto and they didn't carry them. but then I went to Auto zone and they had them.
  6. j miller
    Polson, Mt
    thanks i 'll try there
  7. GTwannabe
    GTwannabe Member
    Acworth/Kennesaw, GA
    94 mustang GT, '73 Comet GT 302 toploader 4-speed
    I dont know about all advance auto part stores but I was at work today and found them. that is the upgrade right 194 bulbs for 2825 bulbs? why??? brighter or do they last longer. i did notice that they fit alot of european cars.
  8. Earl Branham
    Lugoff, SC
    GT; the 2825 bulb is a higher wattage bulb, and is much brighter. You will definitely notice a difference.
  9. rayzorsharp
    I did this conversion on one of my cars today. After doing a little running I found 2 of the 2825 bulbs at Auto Zone. I went across the street to O-Reilly and they had none. They did find out however that a Wagner bulb 17177 is the same bulb. I checked it and it was the same thing (5 watt). Another thing is you really only need to purchase three of these bulbs. All of the other bulbs are for the blinkers, idiot lights, and dimmer light. It's not really necessary to change all of those as they are bright enough already. There are only three cluster bulbs that come on when you turn the headlights on. When you pull the panel out from the dash you can plug it back in and tell very easily which ones are coming on when you look at the back side.
  10. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    NAPA has them as well under their own part # ...
