Instrument panel lights out--again!
Discussion in 'Technical' started by 19Grabber72, Feb 9, 2012.
  1. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    1972 Maverick 2 Door Sport Sedan Grabber
    Okay, I put in a new headlight switch awhile back and had already ck'd the bulbs etc on the cluster when I went through this the first time--hence I put in a new switch; and then another. Well, things were fine after the second replacement switch, then one day I turned on the lights and NO Instrument panel--again. All other systems are working, less the lic. plate light but I think thats something else. I ck'd the fuse and its still good too.
    Ideas?
    Do you think if the fuse shows circuit that I need to clean those to solve the problem? I know it can't hurt, but is that really the problem?
    Or do you think the new switches are just not very good as I had one from the beginning not work after I put it in--I got mad and bought another and thats how I got it to work again after the first try. Uuugh
    Im all ears as this is driving me nuts! AGAIN!
    Thanks all.
  2. simple man
    simple man Member
    Bunnell,Florida
    One thing I have found on our cars, is that the pins in the plugs push out! Make sure all your pins are pushed onto the switch when you put the plug on! I take a small pick and push each pin after I've put the plug on. All the plugs seem to be the same. The plastic ages and the little tabs that hold the terminal in the plug fail. I hope this does it for you! I know it drove me crazy!!! :)
  3. 9mpg
    9mpg Member
    Raeford, NC
    71' Merc. Comet gt, 08 F-150, 2001 mustang, 98 harley custom,2000 Mercury cougar,98 mustang gt,83 chevy s-10 full race...
    I have had this problem an I agree with simple man also. If the license plate light is out, are the park lights out also? Its usually like simple man said the fuse is good but it can be lose or not all the way in. Try wiggleing it with the lights on, I guessing head lights are still on but park lights, license plate light, and insterment panel lights are out, if it is loose or backed out these will flicker on an off and the fuse block space the fuse sits in is the problem.
  4. injectedmav
    injectedmav Member
    Georgia
    Another thing to consider is the ground for those lights, either at the cluster connection or where it grounds to the instrument panel.
  5. mercgt73
    Do the Heater-A/C panel lights work? They are fed by the same LtBlue-Red wire from the headlight switch. If they work, then the cluster is an isolated problem. If not, then move your diagnostics back to the headlight switch.
  6. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    The lighting is gone from behind the Heater/fan panel as well. So Im thinking switch again.
    I looked at the harness connection before I stuck 'er in, and didn't seem to be nasty looking, and the wires going from all that seemed alright. Almost think there is a bare wire somewhere ( but I'd think that would give me an on off thing/ flicker) or like stated a ground somewhere that is not happening.
    Where is the ground up there?
  7. mercgt73
    It is not going to be the cluster ground, because the HVAC panel lights have their own ground, they do not share the cluster ground.
    When the instrument lights are not working, does the instrument lights fuse show 12V+ on both sides? I think it is the #3 (little short fuse).
  8. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    K not an electric sort of guy, but if you mean when I touch the ends of the fuse with a test light does it come on? And yes I believe it is the #3 . . . If I recall yes, but maybe just one side? Not sure about the one-side thing, I would have to ck.
    If you mean another way of testing, please advise.
  9. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    When the instrument lights are not working, does the instrument lights fuse show 12V+ on both sides? I think it is the #3 (little short fuse).[/QUOTE]
    So, tell me then if one side shows 12 and the other doesn't then where do I look or move to fix this very irritating problem! lol Craziest things are sometimes the smallest eh.
    Thanks in advance for your expertise.
  10. injectedmav
    injectedmav Member
    Georgia
    The fuse would be open(blown) with 12v on one side and not the other.
  11. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    Oh thats right isnt it. I knew that, guess I was thinking the volt statement was going somewhere else. Or at least I was thinking differently about it all.
  12. rthomas771
  13. mercgt73
    Yep, make sure you have 12V+ on both sides. If not, the fuse is blown.
    If it is blown, let us know. So we can move on to the next step.
    Just take it one step at a time, we will help you figure this out. (y)
    Oh, and make sure to keep checking the instrument panel lights. If they start working, we have to change our diagnostics. Welcome to the world of intermittent problems.
  14. mercgt73
    This should help you. I highlighted the circuit that we are troubleshooting.
  15. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    Oh my, thats a nightmare! lol I put a new fuse in and the darn thing sparked and blew as soon as I pulled the lights on. Suggestions. Sorry it took so long to get back to this problem. I needed a break and was working on some other things. Still looking to fix this issue. Thanks all.
