Intake and carb setup?
Discussion in 'Technical' started by jhonny18c, Mar 7, 2013.
  1. jhonny18c
    jhonny18c Member
    ottumwa, IA
    1972 ford maverick
    So I have 72 maverick with a 302, im not very knowledgeable when it comes to carburetors so what would be the best setup for daily/track use
  2. Bryant
    an edelbrock rpm air gap with a 600 cfm doublpumper holley carb will work well. it will leave you room to grow into more motor mods like heads and cam.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    A double-pumper not good for fuel economy, and is best suited for cars with a manual transmission.
    A 600 cfm vacuum secondary (Holley) or air valve secondary (Edelbrock) carb is a better choice. If the engine is otherwise stock (cam, compression ratio, heads), a standard Performer (Edelbrock) or Action Plus (Weiand) intake manifold is all you need.
  4. baddad457
    Intake ? Edelbrock Performer RPM, or Air gap, Weiand Stealth or Ford A321, top it with a 570 Holley Street Avenger. You do not want a double pumper Holley for a daily driver, unless you just like buying gas. The Performer 289 intake ? you're better off buying a used stock 4 bbl intake for $50. The ones I listed above will allow you room to grow on for furture mods while still keeping the same bottomend performance.
  5. 71gold
    X2...570 Holley Street Avenger...:chirp:
  6. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Weiand is my fav, I have a Weiand Stealth with a Holley street avenger 670 vacuum secondary but the motor is no where near stock :D Need a little more info on your 302 before a opinion on carb size.
  7. olerodder
    olerodder Member
    NorCal
    Just need a little more information on the motor, trans, and rearend before suggesting something....................................but if is mostly stock I'd have to agree with the 570/vacuum advance.
