Intake Manifold coolant fitting
Discussion in 'Technical' started by Max Power, Sep 9, 2004.
  1. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    As many of you know, when you put an aftermarket intake on a small block Ford, the 90 degree elbow that one of the heater core hoses goes to right behind the thermostat doesn't fit. The hole in the aftermarket intake is one size bigger.
    While I had little problem finding a replacement that goes straight up, I am having trouble finding a 90 degree one.
    Any advice on where to get one?
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
  3. don graham
    never had that problem, but what is a heater for. only supposed to be about 110 here today. j/k:slap:
  4. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Try the Help section of your local auto parts store.
    They carry several types. The aftermarket intakes
    tend to be harder to match.
    Seth
  5. Craig Selvey
    Yeah....you should be able to find a brass fitting that will adapt one to the other. Napa has all kinds of stuff like that. I had to get one for my intake.
  6. don graham
    another place i found to have a lot of fittings like that is ace hardware.
  7. Mavaholic
    NPD carries the 90 degree fittings. You can buy bushings at Home Depot or almost any big hardware store.
  8. tony4eight
    tony4eight Member
    90 degree fitting
    I ran into the same prob, I just put my straight one in the back and plugged the one buy my dist. Everything worked fine.
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Its been so long since I did mine that I cant even recollect having the problem. Now, no heater, so I just plugged mine.
    Dan
