intake manifold
Discussion in 'Technical' started by wyliedx, Feb 18, 2010.
  1. wyliedx
    wyliedx Member
    Afghanistan
    maverick
    I have a 77 maverick with a 302 in it. I installed a edelbrock air-gap intake manifold and 4 barrel carb. Since I did that, I've been having water leak into the oil. I since have taken it off and reinstalled it. But I'm still leaking water and ideas?
  2. rthomas771
    Did you put sealer on both sides around the water ports? The gasket will not seal without it.
  3. wyliedx
    wyliedx Member
    Afghanistan
    maverick
    Yeah I did. Sealant all around it
  4. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    all I can think of is to make sure you have the correct intake gaskets that fit your water ports with no overhang. I got the wrong ones a few times(never knew there was a diff) years ago and had a water leak also. The gaskets are the same except for the water port area. Also, not sure how you are installing it...but I always put 4 long carb studs(or 1/4 redi-rod will do) into the heads(two each side) when I am ready to drop the manifold. I then drop the manifold over the studs which will guide everything down strait and evenly and keep the gasket in place. After I put in a few bolts I remove the studs and torque the bolts as usual.
  5. sierra grabber
    sierra grabber Certifiable
    northern nevada
    get the edelbrock man gasket... the stock 302 ones all leaked on me as well.
