Intake Manifolds
Discussion in 'Technical' started by dudi, Jun 8, 2007.
  1. dudi
    dudi Member
    hi
    i have 302 engine and i think over about Intake Manifolds.
    my carburetor is holley 4150 600 CFM DP .
    i think about
    summit Stage 2 \air gap \ Stealth
    so what are you recommender ?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Really should hear more about your combination
    Camshaft
    Compression
    Heads
    Headers or Manifolds
    Automatic or Manual Trans
    Gear ratio
    Primary use of vehicle
  3. stmanser
    Davenport, Iowa
    i would agree with maverick1970
    but a good manifold for power is the RPM, and a good manifold for just a daily driver would be performer.
    but it does depend greatly on your setup
  4. lbr
    lbr Member
    Fresno, CA
    11 second '72 Comet, 302, 4 spd
    There has been quality issues with the 'Summit' branded manifolds.....Imported! Do a thread search, I think it's been covered here before.
  5. bmcdaniel
    Hard to go wrong with an RPM or Stealth. Some guys swear by the Xcellerator on the street, too, 'cause it's a relatively small single plane. The only measurable difference between an RPM and an AirGap is the price. The Performer is strictly a low rpm range aluminum version of the stock Ford four barrel intake. Obviously your heads and cam need to be a part of the combo.
  6. tim keck
    sharps chapel,Tn
    I like the stealth,works well with mild engines and will still work good if you turn it into a not so mild engine.Mine worked well up to 6200(thats where the heads ran out though,me thinks the stealth is rated up to 6500)
  7. Maverick Man
    California
    uh oh... i hear a manifold debate...coming lol!
  8. Blown 5.0
    MS.
    1974 Maverick
    The Blower manifolds are the best, But the stealth is also a good all around manifold.
  9. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Stealth... (without know more specifics)
    I see you have a DP carb.
    If you don't drive the car regularly, have a manual tranny, and decent gears... Then you could use the DP with an X-cellerator and get very good results.
    If you don't have all of these things, you really would be best off considering a change to a vacuum Holley carb.
