Intake suggestions
Discussion in 'Technical' started by cam1000, Dec 27, 2006.
  1. cam1000
    cam1000 Member
    Eastern North Carolina
    I am planning to go with a 302 out of a 85-6 thunderbird with c5. Leaning towards edelbrock rpm cam, 3.89 gears ~28" tires. For any one using a something similar to this combo what intake are you using, and how do you like it. Thanks for any info.
  2. Blown 5.0
    MS.
    1974 Maverick
    I would be intrested in knowing how the C5 works when you get it in, Are you going to use the lockup converter? P.S. BLOWER INTAKE with blower and i LOVVVVVE IT.
  3. grbmaverickmo
    Aquashicola, PA
    performer rpm
  4. cam1000
    cam1000 Member
    yes, i will use the stock converter. (at least at first)
  5. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    1973 Ford Maverick Grabber ginger & white factory 302 c-4 car LDO package
    love my air gap.. I would offer a couple of suggestions a nice 650cfm carb and some headers and loosen up the convertor a little
    rpm cam runs 2500-6500 it's a revver.. you might find you will need 4.10s with those 28 inch tall tires or more..
  6. cam1000
    cam1000 Member
    which air gap do you have? "4.10s" yea all the specifics are still up in the air. I have a set of 4.11 that will fit the factory rear end, but i also have a 9" axle with the 3.89's and i would prefer to go 9". All this stuff so far is "free" stuff, and i am trying to keep the budget down for now. 28" tires, well this is not in stone either. Our first maverick we ran on the strip had 28"s on and it looked really mean. Buy anyways. 650 cfm has been noted and thanks for the reply.(y)
  7. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Performer RPM or RPM Air gap,also if you use a cam that big with a stock converter it will be a dog off the line and at low rpm.I would be looking into a good 10" conv.
    Derek.
  8. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    You're gonna get a hundred different suggestions here. I vote Performer RPM...
  9. Maverick Man
    California
    ditto... or air gap (same crap) if you wanna spend a little more.
    others can swear by other intakes but think about it... this is the newest one on the market and it has been proven even over their other manifolds.
  10. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i have ported RPM air gap w/ holley 750 not sure how good its goin to work but its what i got:)
  11. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    http://www.putfile.com/pic.php?img=3150422 this one (the fuel stains are cleaned off now looks nice again) the rpm airgap for the 302s part number is...
    Ford 260-289-302 V8
    RPM AIR-GAP 302 (1500-6500 rpm)
    Designed for street 289-302 c.i.d. Ford V8s, the RPM Air-Gap incorporates the same race-winning technology that's been used on our Victor Series competition intakes for years. The air-gap design features an open air space that separates the runners from the hot engine oil resulting in a cooler, denser charge for more power. Includes nitrous bosses. No provision for exhaust heated chokes and no exhaust crossover. Aftermarket 4-bbl carbs are not compatible with Ford Auto Overdrive Transmission (AOD) unless used with Lokar bracket SRK-4000. Available with standard finish or new EnduraShine finish for a look you've go to see to belive, see Optional Finishes. [​IMG]
    RPM Air-Gap 302#7521*:dance:
    also if you live in a "cold" climate.. it can be a tad touchy to start without exhaust crossover heat.. price you pay for reduced detonation and enough plenum volume to run a over .500's lift cam.. if you live in a colder climate (say upper midwest and east coast north of virginia and plan on driving in the winter go with a normal non -air gap rpm intake you will thank yourself in the middle of winter (subject for another forum thread)
    well I as for the 650 it's a dual plane intake so you can run a larger carb (within reason) and not kill drivability I ran my combo thru the holley carb picker on www.holley.com and it recomended this carb or a 750..
    I picked the smaller one for drivability and the 650 baseplates are identical to the 800 cfm baseplates..
    swap the carb body and wallah instant bigger carb.. (reason I picked a hp vrs a standard 650cfm dp it has the 850 dp baseplate already)
    I have a 750 vacuum carb also.. I will see if it wants a bigger carb in the future .. I will let you know my results
  12. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    I have a old torker 289 needing repair (broken bolt and drilled out carb mounting holes) I want to experiment with be intresting to see old school vrs new school I'll get it repaired and ported to match the rpm heads and see what happens
  13. cam1000
    cam1000 Member
    thanks for all of the input, so far seems like the air gap is the intake of choice. your torker 289 will need some rpm. we have one we have tried on several different 302 combos, and we could never get any power under 2500 rpms. We actually just took it off of the engine in the car now and put our old faithful Cobra intake back on (this thing has worked with everyting, dad just won't part with it even for me) with the torker on the (4500 stall) the car would not stall any more than 2000, and would bog at take off until around 3000-3500 rpm. With the cobra we can stall all lthe way up to 3000~3500 and have instant response. this is on a 302 stock winsor heads high compresson pistons, mechanical flat tappet cam.
  14. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    I have a 6600 rpm pill in the 2 step now(it's the highest one I have).. I'm thinking of buying a 7000 rpm set.. rpm isn't the issue >;) (love those solid cams and roller valve train)
  15. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    funny enough I ran the torker for years on a stock motor it's not as bad as you think, it was originally designed in the mid 70's to fit stock port heads.. it's considered a small-medium plenum intake
    only real problem i had with it is the "carb dimple" in my hood.
    response from that intake to this intake is unknown I broke the bolt off the thermostat housing when I put the new heads on.. forcing me to buy a new intake. I'm not done with this 30 year old intake yet..
