Interior door panels
Discussion in 'Cosmetic' started by fishhog, Mar 8, 2015.
  1. fishhog
    fishhog Member
    comet
    Take a look at the pics and suggest the best method to make these look more presentable.
    The vinyl inserts look good but the areas around them, not so much.
    Can the area be repainted or dyed ?
  2. mercgt73
    mercgt73 Member
    The area around your door panel is the metal, inner shell of the door itself. If it is rusted, then you are going to need to sand, prime and re-paint it.
    The arm rest and the door panel can be cleaned, prepped and painted using SEM's vinyl paint products. I have had great results with their products.
    The chrome strip that runs around the door panel is going to be the tricky part. It is not reproduced. Some people have painted them to match the interior colors, or you can try the chrome tape stuff that hobby stores sell.
  3. rthomas771
    The textured metal door can be prepped with a wire wheel or wire cup on the end of a drill. This will not damage the textured finish like sandpaper
    TM74 likes this.
  4. mav1970
    Exactly :lolup: - I used a wire wheel in my drill and cleaned out the texture on both my doors and then my paint guy did a couple of light passes over it with epoxy primer so the paint didn't fill in the texture pattern :)
  5. fishhog
    fishhog Member
    comet
    Thanks guys. Helps a LOT !!!
  6. adrenalinteufel
    adrenalinteufel Member
    1973 Maverick
    You guys are my muse, I've been racking my brain over how to deal with my panels that look almost identical to fishhog! Thanks for the wisdom.
  7. Zcomet
    Zcomet Member
    Texas
    1975 Ford Comet
    Cool man that sounds helpful
