Interior Trim
Discussion in 'General Maverick/Comet' started by bikerbuck65, May 21, 2012.
  1. bikerbuck65
    bikerbuck65 Member
    california
    maverick
    Are there trim pieces for the A and B pillars? Its been so long since i had my interior together im not sure what im missing....or lost. Thanks.
  2. Craig Selvey
    There are small trim pieces on the A-pillars, where the headliner meets the A-pillar. If yours are missing, you will see a hole. Otherwise...that is it.
  3. Dave B
    On my 73's, the headliner was just folder over at the B pillar. I wonder if they changed it in later years?
  4. bikerbuck65
    bikerbuck65 Member
    california
    maverick
    I see holes in the A pillars but none on the B pillars that is unless my head liner is covering them.
  5. CaptainComet
    Yeah, just on the A pillar. It is a pebbled plastic strip, about 3/8th" or so wide, just a bit down from the corner from the windshield gasket. Tucks into the recess pressed into the pillar. You could probably fab up something simple in a pinch.
    Headliner is just folded over down a bit on the B pillar on mine too.
