Interior Work
Discussion in 'Cosmetic' started by MrMaverick70, Jun 27, 2020.
  1. MrMaverick70
    MrMaverick70 Member
    Kalona, IA
    1970 Ford Maverick 2D
    I recently bought a 1970 2D Ford Maverick. The exterior was in great shape. But the interior needed some work. That's what brought me here. The rear interior quarter panels have started to crumble and crack. I could use some tips on how to handle this. I've been looking on trying to find replacements but it seems almost impossible. Is there anyway I can repair it and make it look good? This is something that will be visible. It is crumbling at the top near where the small window would be. Any help is appreciated. Thanks!
  2. 71gold
    :Welcome:...:Handshake:
    replacement is the best option. repairing them is almost impossible. once the plastic starts crumbling. some have covered them with upholstery...:huh:
    run an add in the ...parts wanted section...and see what shows up.
    Frank
    CA189HJN likes this.
  3. MrMaverick70
    MrMaverick70 Member
    Kalona, IA
    Thank you Frank. I'll have to do that later today.
  4. yellow75
    Tillamook Oregon
    To make matters worse 70 and 71 are the only years that will fit correctly due to the seatbelts in newer years come through those panels instead of under the seat and contour is different
  5. MrMaverick70
    MrMaverick70 Member
    Kalona, IA
    Thanks for the information. I'll keep that in mind when looking for a replacement. I very much appreciate it!
  6. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I did see one person who used like, flex-seal type paint to redo some DESTROYED panels. Looked decent for what it was.
  7. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    I seem to remember someone did a post on repair & painting of the panels. Use the search function, maybe you can find it.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    I think the front kicks are repoped, are the back not made too?
  9. MrMaverick70
    MrMaverick70 Member
    Kalona, IA
    Would anyone know where to look to get new panels? Like any good websites of people parting out their Mavericks? Thank you in advance.
  10. BBMS18
    BBMS18 Member
    75 Comet
  11. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  12. BBMS18
    BBMS18 Member
    75 Comet
    smegnl likes this.
  13. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    There were 3 styles of the rear interior quarters, 70-71, 72-73, and 74-77.
    I am pretty sure looking at the photo's, those marketed by Delta Bay Mustangs are the 74-77 style.
    BBMS18 likes this.
  14. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    What is the difference between 73 to 74+?
  15. BKelley
    Stone Mountain, Ga
    "72" Comet GT
    In 73 the seat belt retractor was behind the panel and beside the rear seat bottom. In 74 the retractor for the 3 point seat belt was moved inside the rocker panel on the interior side and a wider bulge was made in the panel to assist in covering the seat belt mechanism/assembly.
    This tech article covers each.
    http://mmb.maverick.to/resources/rear-side-panels-101.111/
    CA189HJN and BBMS18 like this.
