Intermatiate servo change
Discussion in 'Transmissions' started by GasMan, Mar 28, 2009.
  1. GasMan
    GasMan New Member
    Tennessee
    How is the best way to change the servo while it still in the car?
  2. PaulS
    Loosen the band adjusting lock-nut and tighten the adjusting screw to 10 foot pounds.
    remove the cover (with a big pan under it) then remove the piston and spring. Clean the gasket off the case as required and install the new servo cover, piston and spring making sure that the slot in the piston rod is lined up correctly. After you have it installed back the adjuster out 1 1/2 turns and tighten the locknut. Fill the transmission with the engine idling on Park.
    You will need a 1/2 inch wrench or socket and ratchet, a 3/4" wrench and a small (6") Crescent wrench. to do the job.
  3. GasMan
    GasMan New Member
    Tennessee
    Do I need to drop the valve body? And are their any small piece that may fall out? Thanks for the help.:thumbs2:
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Dont think you should have to loosen or remove the v.b. Its pretty easy i myself dont even loosn the adjuster. Just slip the old servo out and slide the new one back in.
  5. PaulS
    If you tighten the adjuster, the struts will stay put and you won't need to even remove the pan.
  6. GasMan
    GasMan New Member
    Tennessee
    What tranny fluid should I be using? The trans actually is a C5 with a C4 V.B. and converter. Right now I'm using Dex/Mer thats what the stick calls for, should I be using type F?:hmmm:
  7. greasemonkey
    Sedalia,MO
    Most if not all performance converters call for type F.
  8. PaulS
    The kind of fluid is determined by the friction materials used.
    I would NEVER use dexron in any Ford transmission - it has too much lubrication for my taste. With the modified paper friction materials in the C4 and C5s I would always recommend type F.
  9. GasMan
    GasMan New Member
    Tennessee
    Ok thanks i'll change it out.
