is anyone a fan of power steering?
Discussion in 'General Maverick/Comet' started by MikeyBoy, Nov 3, 2007.
  1. MikeyBoy
    MikeyBoy Member
    West Hills, California (Southern Part)
    1970 Ford Maverick
    I think i might need a new power steering pump, and ive been using the search to try to find info on it, or what vehicles may have a fittin replacement etc
    but all i find are articles about people rippin it out in order to lighten the car for racing..
    does anyone like power steering or know which cars might have a swapable pump, maybe other same era fords?
  2. Mercurycruizers
    Venetia, PA
    I have power steering & I like it. I just replaced the pump about a year ago. Along with the hoses. Got it at the local Auto Parts Store. Didn't cost all that much....Less than a $100 for everything.....
  3. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    I like the PS on my 4dr. It is iffy but fun.
  4. MikeyBoy
    MikeyBoy Member
    1970 Ford Maverick
    mine seems to be leaking out where the pulley shaft is, pretty bad too, i bought a new pump, but it doesnt have the pulley attatched so i guess im gonna have to take it to a shop and pay through the nose to have it all replaced :(
  5. MikeG747
    MikeG747 Member
    Arkansas
    Mikey just go to local parts store & buy a pulley puller. It was very easy. I just did mine & it was my 1st time. Went very smooth. Just follow the instructions for bleeding & flushing the system after new pump is installed. That's what I did. (y)
  6. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    Or take it to shop and pay a few bucks for them to pull the pulley.
  7. Craig Selvey
    Or borrow the tool thru an auto parts store's "loan-a-tool" program.
  8. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I'm a fan of PS on the streets and no PS for strip.
    I have one Maverick with (daily) and one without PS (strip)
    I would want to put PS (or do everything within reason to keep it working) on my daily, on doubt.
  9. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    What are they.....I just cleaned up my hoses and brackets and put hoses on and now I don't have any power.
    I emptied the pump and put new fluid in, the hoses I know have air in them. took it up the road and it was if I had a manual steering.
    Robert
  10. tim keck
    sharps chapel,Tn
    You'll probably have to bleed out the system.While it's running,turn the wheels lock to lock a few times.Get the front end up off the ground.Leave the pump dipstick out(at first)Check the fluid,you should have to add some.Do this a few times till you get all the air out of it.When it starts filling up you might want to leave the stick in if you don't want fluid all over everything as it shoots out.I had to do this when I replaced the box AND pump on my '77 Ranger.Both were dry so it took a few times to get it all circulated throughout.I don't know if I done it "right",but it worked.
  11. MikeyBoy
    MikeyBoy Member
    1970 Ford Maverick
    this is all good info, can i pick up all the hoses and stuff at a local parts place, i got minor leaks in many other parts of the system, i wouldnt mind just replacing the whole thing
    on a side note, i now have a set of centerline rims that will be goin on the car, im pretty excited about that
  12. don graham
    i like the power steering on the street. my other car is sometimes hard to steer going slow. course the spool and slicks probably don't help either. i'd fix it and keep it for the street.:)
  13. RobertBailey
    advance and autozone has them. I ordered my there. was confused when I got mine, because my maverick was a 6cyl converted to a v8 and yes the hoses are completely different.
    Robert
  14. Mercurycruizers
    Venetia, PA
    Read post #2....Yes!
  15. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    I love my power steering. When I was rebuilding my '72 I replaced all of the steering components except for the steering gear and added a Total Control Products coil over kit. I also tightened the preload on the gear a bit to take as much of the slop out of the system as possible. The car handles very well...Maverick power steering doesn't have to suck. :)
