is it worth it?
Discussion in 'Technical' started by 1974fordmaverik, Jan 24, 2010.
  1. 1974fordmaverik
    1974fordmaverik Member
    huber heights Ohio
    74 Maverick
    i was wondering if it is worth it to change the drum brakes to disk. i know that it will cost about 1000 which not to happy to buy so is it really worth it or should i just keep the drums
  2. rthomas771
    It shouldn't cost $1,000...maybe $400-$500. You could drill your drums yourself and get better brakes.
  3. Joe Dirt
    upgrading to disc was one of the best things i done to my car. if you shop around you can still find setups in junkyards.
  4. 1974fordmaverik
    huber heights Ohio
    74 Maverick
    thank you for your help on both ideas but im going to prob. what until i get enough time do that. i was just wondering for ideas
  5. sierra grabber
    sierra grabber Certifiable
    northern nevada
    the front disk is increadibly better... im trying to restore a front axle for my truck to convert it now.... worth every penny!
  6. Bob Wiken
    Fayetteville, Arkansas
    I got my front discs in a salvage yard for $100. including tie rod ends, every nut and bolt and even the lug nuts off the donor. Had the discs turned and new pads and an allignmment. Under $200. money well spent.
  7. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    uhh what...drilling drums?
  8. rthomas771
  9. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I have not done my Maverick yet but plan to. I have converted my 71 F100 to discs and would never go back. The drums worked and stopped the truck but the discs are just so much better. Less to no fade when loaded. Always stops straight in an emergency type stop. Easier to maintain. They were very easy to convert also.
    I did a power-steering, power-brake and automatic tranny swap at the same time and it was a complete shock at how much more I enjoyed my truck afterwards.
    The power-disc brakes on the 71 F100 will just about stop anything. Even when pulling a loaded car trailer.
    On a Maverick it also gives you more wheel and tire choices
    clint
  10. Mavman72
    Disc brakes are definitely the way to go with a Mav/Comet.Soo much safer/better...
