Is this a good starting point for a 347?
Discussion in 'General Maverick/Comet' started by Elephant, Mar 21, 2019.
  1. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
  2. 71gold
    a little much being all you need is the block, crank caps and spiders.
    this is what I built my 347 from.
    found it laying in a guys back yard covered up with that piece of carpet and it held down with the blocks and tires. the pan was buried in the dirt and rusted completely through.
    ...$50...
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I agree with Frank, look for a truck 5.0 and save some money. You should be able to get one for a lot less. If you get a 93 or newer truck engine it will have the roller cam and associated pieces. All the blocks from 85 and newer will accept the factory spider and lifters so don't rule those out.
  4. Krazy Comet
    With it having a Fluid damper and underdrive crank pulley, it's no doubt been rode hard and pot up wet. If you aren't interested in the heads, cam etc keep looking.
    Note there is no such thing as a stroker ready block. Any stock block requires the bottom of cylinder bores be notched for rod clearance.
  5. RMiller
    Kennewick, WA
    They used to sell blocks through Summit that were prepped for stroker builds. The might still but I haven't looked in some time.
  6. Elephant
    Elephant Member
    Katy, TX
    1977 Maverick
    Thanks yall! I’m going to pass. And to clarify I don’t mean a “stroker ready” block in that way. But still need a good foundation. My current non-roller 302, for example, isn’t the platform I want.
