It just wont turn over :(
Discussion in 'Technical' started by will8069, Apr 7, 2010.
  1. will8069
    will8069 Member
    Garland, TX
    1974 Comet 250 straight 6
    I left my car sitting out for a while and recently started working on it. When I turned the keys, it just wouldn't turn over. I poured a little gas in the carb and started it up, and it turned over and then stopped. I figured it was something with the fuel delivery system. I checked the fuel filter, and ugh... there was a substance that I think was rust. I bought a new fuel filter and installed it, and still nothing. Fuel is just not getting there. It was working fine before I let it sit out there. What do you guys think the problem is?
  2. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    you might have rust in the carb and the tank my car did that when i first got it got a new tank and cleaned the carb ran much better .... you might want to clean it all
  3. simple man
    simple man Member
    Bunnell,Florida
    Depending on how long it sat,over a month?,the gas has probably gone bad. Drain the tank and refill with new,preferably premium grade gas. The premium has cleaners that regular doesn`t,and will help to clean your fuel system. Also if your car has a 250-6,tap the fuel inlet on the carburetor somewhat gently with the butt end of a screwdriver,as the float needle will get stuck closed from sitting. Good luck on it,you shouldn`t have to do much more than this!:)
    P.S. Check and or replace your fuel hoses. One at the tank and one under the left floorboard right at the front of the door. If these leak air,the fuel pump won`t prime.
  4. 71gold
    :hmmm:...battery dead...
  5. will8069
    will8069 Member
    Garland, TX
    I guess I described it wrong. I could hear it trying to ignite, but it just wouldn't catch. I had just charged the battery. None of this really matters though, because it started :yahoo:
  6. 71gold
    (y)...:Handshake
  7. rthomas771
    Fuel pumps go bad after sitting for a while. Manipulate the throttle linkage...Do you see gas spraying in the carburetor.
  8. justin has a 74
    kentucky
    Im suprised noone else suggested that, he said gas was not getting to the carb:16suspect;)
