Hello all, I've got a very well preserved '76 Maverick, so I put it away for the winter (I live in Northern Ontario, Canada: lots of snow and salt here) to further preserve it. I took the battery out when putting it away, but I forgot to check which wire connected to which terminal. I figure this is important, considering the flow of current. If anyone could help me, I would be very appreciative. Thank you, Liam McDermott
They should be color coded Red is positive, black is negative If they arent color coded then look for a wire that goes from your engine block. That is the negative. The other should be positive and be shorter. It should go to a solenoid on the fenderwell
Yes, it should be but not always the case... Some people think a terminal is a terminal and when replacing just the terminal they just grab one and make it work.
to this board. Your car would'nt be a red, 200 six by chance is it. Its nice to see more Ontario cars coming outta storage. Where in Ont are you.Have fun with the car.
