JC Whitney 4 leafs are installed ....
Discussion in 'Technical' started by dmhines, May 9, 2006.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    .... and the end result is the rear sits 1/2 higher than the front .... Measuring from the rocker the front is 9" off the ground and the rear is 9 1/2 " ....
    So other others have said ... the JC Whitney springs are definitely stock ride height and don't jack up the rear like ESPO and others ...
  2. mercgt73
    Cool! (y)
    Gonna have to update your signature picture now with the new ride height...:rolleyes:
  3. Mavaholic
    Are you running same size tires all the way around? Also did your rear shackle bushings fit the spring eye correctly?
  4. dmhines
    Cumming, GA
    Same size tires all around ... Both the shackle and bushings were identical to the ones I removed when held side by side ... I got the shackle and bushing kit from ESPO.
  5. dmhines
    Cumming, GA
    Unfortunately it's hard to see much difference ... the rake is not what I had hoped for ....
  6. Mavaholic
    Throw a couple of bags of cement in the trunk. That should correct the ride height.
  7. dmhines
    Cumming, GA
    LOL ... I need the cement bags in the engine compartment ... not the trunk .... :) I think one of these days I'll take 1/2 a coil off the front ...
  8. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Just run around on a quarter tank of diesel. ;)
    Good info. And you got free shipping too correct?
    Total?
  9. sierra grabber
    sierra grabber Certifiable
    northern nevada
    concrete in the trunk is for driving on snow or better launch traction:biglaugh:
  10. dmhines
    Cumming, GA
    Just went for a cruise up to Wendy's .... It defintely handles better with the HD 4-leafs .. no rolling around corners. I also notice that in the parking lot the car holds it's stance better even though the parking lot was not level ... :)
  11. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    I could jump up 'n down on front end for a few minutes. That should lower it the equivalent of 1/2 coil or more.:dance:
  12. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Told ya... :D
  13. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Which car?
    Red Grabber or the Gold daily driver?
    Seth
  14. dmhines
    Cumming, GA
    Old yeller got the new springs .....
  15. scooper77515
    I really like the feel of my new 4-leafs...I just wish I could get the ride height leveled out, but it seems to be error in the front of the car causing the lean (might work on that today...).
    It has a much firmer, sportier, holds-the-corners feel, like my old 4-wheel independent suspension Z-car!
