Jittery Acceleration
Discussion in 'Technical' started by Mr Nick, Jan 12, 2015.
  1. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    So in the past two days I replaced some shocks and adjusted to gap on my spark plugs (previously .044) to the computer required .035 gap. After doing this, It was running just fine UNTIL I was at a redlight and decided to spin the tires and then it started sputtering hardcore during anything other than light acceleration and the engine gets real shaky. Do I just need new plugs or what?
  2. Moneymaker 1
    Panama City Florida
    More engine details please, EFI? Carb? what ignition system? automatic or manual trans.?
  3. Mr Nick
    Grapevine, Texas
    Bone stock 250 I6 with 1bbl, automatic.
    It feels like when i accel it pulls left and let off it pulls right
    Diff gear or shafts maybe?
  4. Moneymaker 1
    Panama City Florida
    You said the engine was running rough, that should not make it pull either way, make sure a plug wire has not come off as you said you worked on the plugs.
  5. Mr Nick
    Grapevine, Texas
    Plug wires are fine
  6. Mr Nick
    Grapevine, Texas
    Idle at 20 mph is super rough just fyi
    why is the rear end pulling? Needs trans/diff oil or what?
  7. Moneymaker 1
    Panama City Florida
    Were you power braking (holding the accelerator down with your foot on the brake) during your burn out? if so it could be a brake issue.
  8. Mr Nick
    Grapevine, Texas
    Anyone know how to fix rear steer?
  9. Mr Nick
    Grapevine, Texas
    I was power braking but would that cause the bad idle at 20 and sputtering at 60?
  10. Moneymaker 1
    Panama City Florida
    You asked so I try and give you a reason, which problem do you want to tackle? :biglaugh:
  11. Mr Nick
    Grapevine, Texas
    1. Sputtering first
    2. then rear steer if you'd please.
    3. I talked to my mentor (grandfather), he says check the plugs for possible fouling due to contact with the anti-seize
  12. Moneymaker 1
    Panama City Florida
    Could have something to do with fuel delivery also, there are quite a few things that could cause it to run rough, have you by any chance looked at the oil on the dipstick?
  13. Mr Nick
    Grapevine, Texas
    I have not, I'll check it in the a.m. But I just changed the oil and my fuel filter
  14. x72COMETx
    x72COMETx Member
    Vallejo CA
    You said you replaced the shocks did you replace the rear shocks?
  15. Mr Nick
    Grapevine, Texas
    Yes i did, KYB Excel G's
