Just an update
Discussion in 'General Maverick/Comet' started by Lucifer, Dec 12, 2022.
  1. Lucifer
    Lucifer Member
    Canada
    1972 comet
    D02E5BFF-1D64-44C2-BA59-677CCDA2CC79.jpeg 4AB2DB63-8C03-473F-B1CE-08D548EF8FB0.jpeg 88EA2F59-1E23-484A-9BFC-FE3FC633AD2F.jpeg I hope to have it all good for next summer. Had some initial troubles with the holly sniper , if I was to do it again I would use a new fuel tank with pump inside and make sure the return line was not restricted plus use an external fuel pressure regulator right off the hop. Now I need a hood scoop please in bc Canada ,you guys have been a wealth of info here on this site merry Christmas. and thanks again Brent at GEARSTOGO for the 4 speed swap parts and help.This 425 hp blue print crate engine is f ing insane I crappies my panties a little dropping the clutch first test drive after breaking everything in.
    464925, CaptainComet, Jaybee and 3 others like this.
  2. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    Love that red color...
  3. Lucifer
    Lucifer Member
    Canada
    1972 comet
    I hope it works out I was just flipping through colour cards and picked it going to paint this week
  4. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Looks great!
  5. William623
    Orlando
    1973 ford maverick grabber
    I run the Holley intank pump that bolts into the factory sending location no mods needed. It does not require a return line. Works great with the sniper system.
  6. mojo
    How is noise level on this pump? I’ve heard folks complain about noise on some efi pumps!
  7. William623
    Orlando
    Honestly not bad at all. Pretty quite. The injectors can be a bit loud but it not that bad.
    mojo likes this.
  8. 71gold
    I have the same pump with my Pro-Flo 4 and it works great. when I turn the key on I have to listen for the pump, it only runs a couple of seconds to build pressure then shuts off.
    TeeEl likes this.
  9. Stardust71
    Stardust71 Member
    Raleigh, NC
    1971 Mercury Comet
    Which model are you running? Holly's website doesn't show any as compatible with a Maverick/Comet (Although I always suspected that one of them would).
  10. William623
    Orlando
    It’s the one for the 70 mustang. When I get home I a few days I can get a photo. I actually pulled the whole system and went back to carb. It worked fantastic but I missed the simplicity of it. It’s all i a box right now.
