just got my block back from the machine shop...hoe i can get 'er done by the roundup!
Discussion in 'General Maverick/Comet' started by hewitt46, Jun 22, 2012.
  1. hewitt46
    hewitt46 Member
    White Lake,MI
    71 maverick
    just got the block back...put in crank and pistons today ..... got alot of work left to do! hopefully i will get it done in time ...if it gets close ill be calling on all the michigan maverick guys to lend a hand!! lol:D
  2. don graham
    Good luck. Don't rush it though. Make sure it is done right or it will cost you a lot more time.:)
  3. mavman1970
    mavman1970 Member
    Minnesota
    ditto on what Don says. I had a pile of parts like you 5 days before I was to leave on the Power Tour earlier this month. I rushed to get the motor together and had to redo things I messed up the first time. Little things like rear main seal, oil pan gasket I messed up re-doing the seal....
  4. 71gold
    what motor is it...:bouncy:
  5. Craig Selvey
    You have over a month....you can get it done!! This will be the closest MCCI Roundup Nationals to you EVER!! You have to get it done!! GO!! GO!! GO!!
    Bring it to the parking lot for one of our legendary late night mechanical sessions if you have to!!
