Just read about this trick
Discussion in 'Technical' started by Graybeard, Apr 30, 2006.
  1. Graybeard
    Graybeard Member
    Lawrenceburg Indiana
    I was reading some tips and tricks on another site and ran across this neat trick for installing a thermostat and anti-freeze.
    We all have had trouble filling the system with coolant and bleeding all the air out when you first fill it up.This trick was to install 3 aspirins,120 degrees apart under the disc of the thermostat.This will hold the thermostat open when you install it,letting coolant and air pass thru and out,back up your upper hose.When you start your engine,coolant will circulate right away and as the anti-freeze gets hot and circulates,the aspirin will disslove.
    Just thought I would pass this along,I have never seen it done and have had issues with start up before and hot motors waiting for the thermostat to open fully.(y)
  2. don graham
    never heard that one before. :)
  3. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    Well, I'll be..... don't see why it wouldn't work.
    ...it's the little things that always make you go hmmmmm.
    Later,
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    That is a neat trick...THANKS! for sharing
  5. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    neat trick. i have also heard, if you drill a small hole in the flat part of the thermostat it will also let air escape.
  6. John A Fasig
    John A Fasig Member
    over here now
    several plastic and tin
    if i used speeders insted would my car go faster?
  7. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    That is one of those ideas that is so simple yet I had never thought of it. Wonder which would be better, quick acting or just regular asprin?
  8. hotrod-daddy
    hotrod-daddy Member
    Sometimes the extra pain relief is better...just chase it with a couple of beers:drink: :biglaugh: :yippee: :dance:
  9. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Interesting!
  10. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    If you used Viagra would it help make the engine block more ridged?
  11. fan2488
    fan2488 Member
    spring,TX
    at $10.00 a pill it better do something:rofl:
  12. Mavaholic
    Neat!!!
  13. james comet
    james comet Member
    las vegas, nevada
    1971 comet
    That's an old trick.
    I tried it years ago on my car and she still complained of having a headache! :rofl2:
    james comet
  14. daydreamer
    daydreamer Mavmenace
    Oshawa, Ontario
    1972 Ford Maverick
    the drill a 1/8th inch hole in the flat part has been done for yrs.. just put the hole up at the top of the thermostat housing and any air will automatically bleed itself out.. has worked for me many yrs.. after the air is gone the small amount of coolant that goes thru the small hole is not important.. hope it works for all of you too...
  15. courier11sec
    courier11sec Member
    Tucson, AZ
    I like the aspirin trick. New one on me.
    Thanks.
