Just Scored
Discussion in 'General Maverick/Comet' started by mavdog71, Apr 30, 2015.
  1. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    A top loader 4 speed trans and bell housing it's a C4AR- 7006-A with a HEH-G on the tag 64 mustang 260-289 with hurst shifter . wide ratio
    No idea of condition does any have of value???????????????
    hurst competition plus shifter also a 6 bolt bellhousing and spacer plate
    1 , 1/16" 10 spline input shaft 25 spline out put shaft
  2. yellow75
    Tillamook Oregon
    I would put a value of $600.00 to $800.00 depending on condition, I have that transmission in my Falcon wagon but had to change tail housing to put shifter in correct location
  3. rthomas771
    Is it a 4-hole or 8-hole? I'm thinking the 4-hole fits the early 5-bolt bellhousing only
  4. Krazy Comet
    & all 260 were five bolt...
    Plus it's listed as having a 25 spline output shaft(only very early top loaders have this), not worth much if you're going to beat on it...
    http://www.davidkeetoploaders.com/idchart1.htm
  5. yellow75
    Tillamook Oregon
    Didnt think about looking it up just saw Mustang, mine is from a 66 and is a HEH BW 28 spline. Still should be of value to the right person
  6. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    just add more info to 1st post .
    removed cover great shape inside no warn on synchronize and gears
