Kickdown rod Install??????????
Discussion in 'General Maverick/Comet' started by Flamesoldier, Jun 27, 2008.
  1. Flamesoldier
    Flamesoldier Member
    1973 Ford Maverick 302
    I bolted on my weaind x-celerater single palne, my holley 1850-2 4 barrel, and throttle linkage , all thats left is the kick down rod. How do I install the rod to the bottom I found retainer clips online for the kickdown rod. Does the kickdown lever have a nipple on it? Also how do I adjust my kickdown on my holley ?????? I know i cant adjust rod but i have a kickdown adjust screw????
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
  3. Blown 5.0
    MS.
    1974 Maverick
  4. gageman
    gageman Member
    Frewsburg, NY
    1971 Maverick Grabber Clone,72 Ranchero GT,1997 Ranger
    I've got one of these Lokar's brand new in package will let go for $50.00 plus shipping.
  5. PaulS
    When you change manifolds there is always the possibility that the kick-down rod may have to be lengthened. There is an adjustment at the carb but it has limited range. There is a short 1/4" shaft that is sweged to the lever at the transmission that has a groove for the retainer clip.
  6. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Baaaaaahh.. But how do you get the clip off without breaking it? or do you need a new one? :banghead:
