Kickdown
Discussion in 'Transmissions' started by demo913, Jul 29, 2009.
  1. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    My tranny was rebuilt about 6 months ago and the kickdown was never there to begin with and they did not install one after the rebuild. My question is what do I need to do to install one. It is a c4 with a transgo shift kit. Can you just install the kickdown or is there some adjustments that need to be made? Thanks.
  2. rthomas771
    Yes you need a kick down
  3. Mavaholic
    Never had one on my 77 and never had a problem. Put it together back in 99 and its still running just fine. I was under the impression that it just downshifts the trans when you stomp on it. Can do the same thing with the shift lever.
  4. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I just hear people saying im going to ruin my tans. I'd rather install a kickdown than new trans. Just was wondering what mods or adjustments would have to be made. Or is it just a bolt on?
  5. rthomas771
  6. PaulS
    If you are lazy about shifting then use the kick-down linkage.
    If you are shift-happy it is easy to get away without it.
    The "kick-down" modulates (changes) the governor, modulator and boost valve pressures as the throttle is fed to the engine. It is more than just a downshift valve.
