KYB shocks; GR@, or Gas-a-Just, or GST?
Discussion in 'Technical' started by John B, Feb 10, 2004.
  1. John B
    John B Member
    Ontario, Canada
    '73 Mav
    Searching the archives brought up references to all three of these names under KYB. Apparently the GR2s are available at Autokrafters (fronts and rears), the Gas-a-Justs from PST (fronts and rears???), and the GSTs from Advance (fronts and rears???). Can anyone explain the difference between these 3 "models", or recommend one type over the other, or confirm which ones are available for all 4 corners of a Maverick? Once again, thanks for the input. John B.
  2. dtlcast
    dtlcast Member
    HOUSTON
    KYB shocks, the only way to go.
    To: "'dtlcast@hotmail.com'" <dtlcast@hotmail.com>
    Subject: RE: K Y B TECHNICAL AND CONSUMER REPORT REQUEST
    Date: Thu, 2 Jan 2003 13:49:32 -0600
    David,
    The Gas-A-Just shock for th rear of this model is long discontinued. It was #KG5525. We only offer the GR2 low pressure gas shock # 343136. You could use # KG5519 inverted if you put several 1/4" water drainholes in the dustcover metal cap and if the dustcover does not interfere with the lower shock mounting bracket. The Gas-A-Just, being a monotube, will operate
    upside down with no problem. KG5519 is about 1" longer extended, but thisshould be no problem either.
    Chuck Gonwa
    KYB America LLC
    Product Manager
    Phone: (630) 620-5555
    Fax: (630) 620-8133
    E-Mail : chuck@kyb.com
  3. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    our suspension has gas-a -just on front... g2 in back. we also went with new 4 leaf rear springs. they are kinda stiff and make up for the difference in the two shocks. the car rides sort of rough but you get used to anything. the handling improved DRAMATICALLY! hey chuck- how bout cutting this guy a break on shocks? i got mine from my distributor and got a great deal! i bet you could sell lots of kyb's to mav owners on this board that way! i have the gas a just on all four wheels on my karmann ghia and i wouldn't have it any other way.
  4. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    I just got GR-2's for the front from Canadian Mustang. They are KYB part #343146, $65.15 CDN for the pair. They also carry the Gas-A-Just. The rear Mustang shocks are different from our cars, so I have to find them somewhere else.
