has anyone used a v-belt on a roller motor.....if so what pullies did you use? The crank uses a 4bolt pully.....with the 68 waterpump the pullies ride in each others groves......and that also means they don't line up. I need pullies ahhhhh I have a mix match of s...! Give me a year and model please
I have late model pump on mine from Ford SVO Catalog. Early model brackets don't match up. i had to use spacers and washers with my V-Belts pulleys from March and rig up some threaded rods with tie rod eye bolts on them. Then you can adjust them to where ever you want to. Good Luck
