Leaf spring replacement
Discussion in 'General Maverick/Comet' started by mavdog71, Apr 16, 2006.
  1. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    What should i do replace rear leaf spring with 4 leaf or 3 leaf springs my car is a driver not race car like to use it for trips top arizona nor cal and so on
    will be ordering from jc whitney want the car to ride smooth mot like lumber wagon
    thx jay
  2. Old Guy
    Old Guy Member
    Three will do just fine with some decent shocks.
  3. Mercurycruizers
    Venetia, PA
    You saw my car. It has 4 leaf springs in it. I just had them done before the trip south. I even had them rearched to sit 1" higher than stock. The ride down & back was fabulous. I'm glad I went to 4 leaf. I'm surprised they weren't a stiff ride. Very smooth indeed. Maybe the KY shocks all around helped also. Go with 4 leaf for sure....
  4. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    If you want a soft ride, then 3-leaf is the way to go. Keep in mind that they will eventually sag over the years just like your originals did. I went with 4-leaf to avoid future sagging, but it does ride stiff...
  5. |MaverickMat|
    |MaverickMat| '74 Grabber
    Portland, OR
    1974 Grabber
    On that note, for a car with an objective of some street use on the weekdays and racing on the weekends, how many leafs would you recommend? I recently came upon some springs that have six leafs in them, and I assume that is going to equal a very stiff ride and poor traction around corners. I've got stiffer springs up front (about 520lbs rate) and I'd like the rear to match. Would it be all right to simply remove one or two springs? Or do I need to go and purchase a completely new set?
    *EDIT* Sorry, I should have specified; I'm hoping on doing more autocross type racing than straight line racing. Would stiff shocks/soft springs work in that application?
  6. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Track setup = stiff shocks, soft springs.
    (from what I was told anyway)
  7. T.L.
    T.L. Banned
    Southern Colorado
    If I had it to do over, I'd go with 3-leafs, stiff shocks, and lower the front to match. My car rides like a brick $#!t-house...
  8. Mavaholic
    I have 4 leaf from JCW and they ride pretty good IMO.
  9. j miller
    Polson, Mt
    i also have the 4 leafs from j c whitney and am very happy with them. also KYB shocks front and rear
