Leaf springs 3 or 4 ??
Discussion in 'Technical' started by boss9, Jan 3, 2006.
  1. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    Was looking at J.C. Whitney for leaf springs. They offer 3 or 4 leafs for same price. Anyone tell me the major differences. I have a 69.5 (will this effect anything ?)
    Thanks, Darrel
  2. Mavaholic
    I bought a set of 4 leafs from them. They fit great and did not raise the car up any. Only problem I had is the rear shackel eyes are about 1/8 bigger diameter than the bushings. Nobody else seems to have had this problem. I'm not sure if it was just a fluke. I called the manufacturer of the springs & they would not help me so I called JC Witney and after a couple of weeks, they said they cant help me. Its not a huge deal because once tightened, nothing is going anywhere. Next time I go to Carlisle I will look for slightly larger bushings.
  3. MikeG747
    MikeG747 Member
    Arkansas
    Darrel I'm not sure which is best. All my Mav's are original Leafs as far as I know & my 73 & my son's 77 both have 3 Leafs. My 74 has 4 Leafs. My 74 rides rougher but I'm not sure if 4 Leafs is the reason or not. :huh:
  4. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    :huh: I don't know, I would like a little more height than stock but I don't want the ride of a truck either ! Thought about just adding a leaf to my originals but they are just about straight across !!!
  5. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    If you get the 3-leaf, they will eventually sag just like your originals did. Also; I got tired of bottoming-out on the pinion snubber when going over dips in the road with the originals, so I installed the 4-leaf (from JCWhitney). The spring-eyelets were no bigger than the bushings, so I don't know why Dennis had that problem. The 4-leafs did not raise the car in the rear....it sat level. I used my original stock rear shackles. it does ride noticably stiffer than the old 3-leafs did, but this ain't a luxury car, so I don't mind...
  6. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    :90: oh so many decisions !!!! I guess 4 it is. Thanks guys.
    Darrel
  7. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Love my 4 leafs!! JMO. Preston
  8. 71gold
    4 leaf from J.C.W.,got lift and rides like a wagon.:yup: ...frank...:bouncy:
  9. Stingrayiii
    Stingrayiii Member
    Las Vegas
    1973 Ford Maverick 302/auto
    springs
    Well I kept the stock 3 leaf in the front. And put 4 on the back. The ride handles great this way. The car would start to shake at about 75. Now I can max out the speed up to 120 and it bearly starts to shake. Plus it raised the back just a hair to give it a more agressive look.
  10. sierra grabber
    sierra grabber Certifiable
    northern nevada
    you have leafs in the front?
  11. Stingrayiii
    Stingrayiii Member
    Las Vegas
    Sorry that is not what I ment. I used to have 3's on there. Stupid me...:coco:
  12. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
