Leaf Springs
Discussion in 'Technical' started by Crazy Larry, Feb 4, 2012.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    If I wanted to remove a leaf from my 4-leaf rear springs to make them like the stock 3-leaf configuration, which leaf should I remove?
    The 4-leaf just rides too stiff for me.
  2. Acornridgeman
    Wisconsin
    Hi Larry,
    I have done this before with trucks. Start with removing the smallest one first. Then drive it around and see how you like it. If it is still too stiff, pull the next one and put the smallest one back and try it again. If that still is not enough to get it where you want, repeat pulling the 3rd leaf and put back the 2nd one again.
  3. mojo
    I have the same issue w/ my 4 leafs - rides a little harsh. Have not got arnd to making any changes yet.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I was just wondering, since I got rid of my original springs (3-leaf) years ago, if someone could tell me which leaves to remove to make them identical to the stock springs.
    It's got to be either the shortest (is that the "overload"?), or the one right above it. I'm certain that the 2nd leaf would not be the one to remove. If I'm even saying this right -- I'm considering the top spring to be the "1st".
  5. 71gold
    I think that most think the bottom leaf (short) to be 1st...I know I do...:yup:
  6. Craig Selvey
    I guess it all depends on either:
    A. How it was assembled
    B. Which way you are looking at it
    :D
  7. 71gold
    when I remove a leaf, I have the spring flipped up on the eyes....that makes the short leaf 1st...:yup:
  8. Craig Selvey
    But when I install a set of leaf springs, I install the spring with the eyes first.
    :D
  9. mictn42
    mictn42 Member
    Goodlettsville, TN
    75 Maverick
    Leaf Springs are a serious pain in my ride...lol I need to do some work on mine as well but I have to say when I look at them the bottom spring would be 1st
  10. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Back in the day, I just pulled the bottom two out and it rode much better.
  11. courier11sec
    courier11sec Member
    Tucson, AZ
    I just take my one ton Cummins out for a ride empty. Then everything seems to ride nice.
    :rofl:
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    So with all the Maverick owners here, no one has a picture of the stock 3-leaf springs???
  13. Allen Small
    Allen Small Member
    Cannonsburg, PA
    73 Grabber/V8 and 72 V/8 grabber
    I have a set of old 3 leaf springs I can take a picture of tomorrow evening and post for you Tuesday if that will work for you. I pulled these off my 73 grabber and replaced them with new 4 leaf springs. The car sagged in the rear somewhat with the old 3 leaf springs on them.
    Allen Small
  14. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That would help a lot, and I'd really appreciate it.
  15. mercgt73
    Here's a pic, not sure if it is close enough for you.
