Leak
Discussion in 'Technical' started by JLB, Jan 17, 2006.
  1. JLB
    JLB Member
    :hmmm: On my son's 77, it has some leaks somewhere that I can't seem to find. The carpet in the front and back is wet almost continiuosly (it rains all the time in WA). I replaced the roofrail door w/s and installed the lower door w/s (previously there were none). The window seals front and rear are ok. Any ideas where this may be coming from? Do I need to pull the seats and carpet? BTW, there is a small rust spot all the way through by the hockey trim on the passengers side.
    Any ideas would be really helpful. Thanks in advance.
    Jim
  2. Jamie Miles
    Cowl vents? :huh:
  3. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Hey Jim,Lived in WA for a few years...it does rain the biggest part of the time. Like others suspect the cowl vents(you should be able to pull the carpet back enough at the front to tell if water is trickling down the floor,but if the hockey stick trim is rusted....I would suspect that area.....
