leaking gas
Discussion in 'New Members Forum' started by busyb187, Nov 22, 2010.
  1. busyb187
    busyb187 Member
    california
    1971 ford maverick v8
    hey everyone. i have a prob with my carter carb. it leaks gas from where you connect the throttle to the carb. i thinks its called throttle linkage, im not too sure. and its smells alot like gas inside the car. ive noticed the smell for about a week but until today that i opened the hood to check it out i saw that gas drops where leaking from there. any ideas?
  2. Mavman72
    If its leaking at the throttle shaft (where it comes out of the carburetor) It needs to be machined and bushed to stop the leak. Be certain of where the fuel is coming from.You may need to simply rebuild the thing and throw new gaskets at it.Good luck!!!
  3. Cowboiup1979
    Cowboiup1979 Member
    Louisville Kentucky
    1976 ford maverick 302v8
    If it's the front of the throttle linkage where the accelerator pump arm is, and is runnign down the accel pump arm, it could be as simple as replacing that rubber diaphragm on the accel pump... something to check... holleys are bad about it i hear, and i know mine needed one when it was leaking... tends to run down that arm and over torward the throttle connector to the pedal cable.
  4. busyb187
    busyb187 Member
    california
    diaphram pump
    to replace the diaphram on the accelere\ator pump on a carter afb carb do i need to take it apart?
  5. motormouth
    motormouth New Member
    Montreal,Quebec -Canada
    No longer have/drive one
    Do not mess around with a fuel leak because leaking fuel on a Hot intake manifold is a fire waiting to happen.Fix it a.s.a.p. is the Best advice I can offer you at this time.Good luck!
    Cheers,
    Motormouth
  6. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    This man speaks the truth. Observe: http://www.facebook.com/album.php?aid=2067053&id=1323294578&l=1b0ccb9ca6
    I'd just rebuild the whole thing. AFB's and their Edelbrock cousins are very easy to do, even if you've never taken apart a carb. It's probably a needle and seat, stuck float, pump diaphragm or a gasket. One $40 rebuild kit and a couple hours of your time and all of those possibilities will be covered.
  7. 302-72-mav
    302-72-mav Member
    sactown CA
    if i rember right he has rebuilt the carb recently
