Leaking Windshield/Drivers Door Weather Strip
Discussion in 'Cosmetic' started by BrewDaddyDave, Sep 15, 2015.
  1. BrewDaddyDave
    BrewDaddyDave Member
    Miami, FL
    1975 Ford Maverick
    Hey guys,
    I have water leaking at a pretty good rate from the drivers door/top corner of my windshield. Is it worth getting a new windshield weather strip ? Could I seal it with something instead? Here's a photo of the problem.
  2. mojo
    You might be able to seal it -- you can try. That wud be a temp fix at best. Removing the windscreen and replacing the rubber gasket is the best permanent fix.
  3. 71gold
    and at that the leak may just move to another spot. I've had 4 windshields installed and all leaked...same story with a lot of others.
  4. Craig Selvey
    You definitely need a new weatherstrip.
    71gold likes this.
  5. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    If your headliner needs replacing it would be a good excuse to do both.
  6. mojo
    I've only had one replaced May 2014; guess I got lucky -- so far no leaks.
  7. BrewDaddyDave
    Miami, FL
    1975 Ford Maverick
    What would you recommend in regards to sealing?
  8. mojo
    I probably wud try some windshield sealer sold in all the auto stores. The way that gasket looks, at best, it will only be temp fix. That gasket is just plain dry rotted from weather/ultra violet exposure. If the car is not garaged, or under some sort of shelter -- you need to do it soon.
  9. 71gold
    once the gasket cracks it will keep shrinking. that will keep the gap opening wider and wider.
  10. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    I bought a new gasket and clips and I'm having a new windshield installed next week. The gasket that's in there is so dry rotted, it has several 1/4 inch gaps inside. I tried all sort of sealers and it just slowed down the gushing.
  11. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Hi Wolfheads:
    Noticed your post. Have you checked your ' cowl ' area for leaks also ? It's a common occurrence for these cars .
    What part of Florida are you in ? We're in DeLand , Fl.
    Cometized
    ( Chip )
    William623 likes this.
  12. 71gold
    what clips did you get?
  13. wolfheads
    wolfheads MadMav
    Florida
    In the AutoKrafters catalog, it's the brown clips. However, there's two different size clips for the windshield trim. I went ahead and ordered 10 each of the other clips just to be on the safe side. They have 3 different sizes listed. 30 and 40 cents each.
  14. wolfheads
    wolfheads MadMav
    Florida
    The guy got the windshield out today and thank goodness there's only a little surface rust inside the frame in which he said he would remove all that. He got all the trim off and didn't damage any of it. I was worried about that. This man knows his stuff.
  15. 71gold
    how many...windshield stands...did he find?
    installing the glass ,it not leaking....installing the trim and not messing it up is the..."knows his stuff"...LOL
