LED BULBS for the rear tail lights
Discussion in 'Cosmetic' started by 302-72-mav, Mar 12, 2010.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    has any one used the led bulbs on there older cars
    any pic's and what color lights did you use
    [​IMG] [​IMG] [​IMG]
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    i tried the top ones. put them in my truck and the grabber and they would not work, so i took them back. someone modded semi truck light led sets to fit in a comet tail light and it turned out pretty nice. those require some wire modding but that seems to be the answer. Im thinking about doing something similar to that for my pickup and the comet. may be dependant on what type of LED assemblies i find in the junkyard....
  3. rthomas771
  4. 71gold
    i tried the ones at the top right...they only lit up a red dot in the middle of the lens...
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Looks like Jeff's Falcon lights light up in four places on the outside, with a "hot" spot lit up in the center. That's the problem with LED's, the light is directional. We have some new trailers with the LED's, the tail lights light up in a kinda snowflake pattern, not filled in like a normal bulb will do. Even if you had a custom LED strip light made for a Maverick, it would still look like you had a row of tiny lights.....
  6. 302-72-mav
    302-72-mav Member
    sactown CA
    what lights are brighter but still will light the whole tail light
  7. 71gold
    i use...2057...they appear to be brighter...the base is less corrosive...
    specs. say they are the same as...1157...:huh:
  8. sierra grabber
    northern nevada
    I thought you were going for the rows of dots look. for brighter lights, upgraded bulbs like frank suggested will make you MUCH happier.... Also take the tail light lenses off and scrub them, because years of dust doesnt look that bad until you clean them and see just how bad it was. Also make sure your ground points are all super cleaned of any rust. old style bulbs really show any current loss. i actually upgraded the lights on my 73 truck to have a "ground cable" with the newer plastic\sealed tail light assembly and put the same bulbs back in. night and day difference!
  9. 71gold
    when my new wireing harness was installed, i bought some new sockets for the rear lights that had a...grounding spade.. on each socket. they were wired to a grounding stud. now the socket doesn't depend on it being secure in the tail light to get a ground...(y)
    ...Frank...
