left turn signal
Discussion in 'Technical' started by maverick306, Aug 7, 2013.
  1. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    Left signal works until I turn headlights on then it stops flashing and gets bright.When I unplug socket it flashes .I ground it gets bright Volt meter has 13.50 until I turn headlights on it goes to 12 volts
  2. Craig Selvey
    Sounds like a bad bulb to me...or the bulb is in the socket backwards.
  3. simple man
    simple man Member
    Bunnell,Florida
    I'll go with Craig on this. It is difficult, but possible to get the bulb in wrong! I'm also assuming this is the left rear signal? When you pull the socket out, you lose the ground and the current back flows through the other lights. It is also possible the socket is wired wrong or the wrong bulb is installed. :)
  4. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    turn signal
    I had put one wire regulater on and didn't ground it I thought it being bolted to the engine was OK. I guess you could call it a two wire regulated. Thank for the input.
  5. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    turn signal
    Jumped to quick put steering wheel back on . problem came back. bulb in right.
  6. mav man
    mav man Member
    wi
    70mav
    check the ground
  7. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    turn signal
    Found problem when l was re doing the wires back lights got them crossed up. Fix now. Thanks for the responses that I received.
  8. Craig Selvey
    My analysis of the syptoms were correct...just the wrong diagnosis. :D
  9. Krazy Comet
    A blinking backup light would have been a good clue...
  10. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    turn signal
    It didn't have anything to do with my back up lights
