Lincoln Versailles front brakes
Discussion in 'New Members Forum' started by barnfind, Apr 22, 2010.
  1. barnfind
    barnfind Member
    Iowa
    Has anyone out there used Lincoln Versailles front brakes and spindles on a maverick? Mine is a 70 w/ the four bolt hubs. The spindles look the same but carry different Ford part nos. than the late maverick/granada spindles. I'm afraid of geometery differences that would prevent front alignment. Thanks.
  2. mav1970
    Granada and Monarch front disc brake spindles are pretty much a straight forward swap. Isn't a Lincoln Versailles simply an over bling Granada and should fit also? :hmmm:
  3. lastchance
    lastchance Member
    Hingham , Massachusetts
    Lower ball joint taper is larger on the Lincoln the rest is the same.Mustang Steve .com sells a tapered spacer to cure the problem.
