line lock
Discussion in 'Drag Racing' started by HOMERMAV, Aug 16, 2010.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    what do you use and how does it work.
    thanks john
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    It's a solenoid that keeps line pressure after you have released the brake pedal. Works off a momentary switch. I would roll through the water box,push the brake then hold the line loc switch. (Mine was mounted on the shifter) that release the brake pedal. The line loc will keep the front brakes tight. That allows for a good burnout cause the rear brakes are released. Easy to install. Solenoid mounts inline with your front brake lines. 1 hot and ground.
  3. jmgford
    jmgford Member
    Iowa
    I have a coiled cord (like a phone cord), that plugs into the line-lock wires under the dash and connects to a trunk release button that snaps into the hole in the left spoke of my sport steering wheel. It installs in less than a minute when I go to the track.
  4. PINKY
    Louisville, Ky.
    1970 Ford Maverick
  5. yellow75
    Tillamook Oregon
    So Jack does your trunk open when you press the button :biglaugh:
  6. jmgford
    jmgford Member
    Iowa
    That's how I slow down. It's the poor man's parachute. :D
  7. rayzorsharp
    This is exactly how I have mine set up.
  8. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    really what i wanted to know was what brand you use.sorry for the confusion i know how they work
    thanks john
  9. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Biondi I used.
  10. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    I've used both a Hurst, and a Jeg's brand line loc...both worked fine with no issues. The Jeg's was a lot cheaper.
  11. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    I have a Summit brand. Probably the same as the Jegs, but it resembles the Hurst model.
  12. darren
    Ok you confused me too. I kind of figured you should know how it works.:hmmm:
    So what your asking is what brand and how well does it work??
  13. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    exactly!!! i was a little tired when i posted this
  14. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    what i need is something to help hold me in the water box better and that means a line lock but i dont know which one to buy.
    john
  15. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    I did have a issue with Summit brand, may have been a fluke, I'm quite happy with my Biondo line lock, # SBR-LL $39.88 at summit, ships today! PS. it's 7 cents cheaper over Summit brand!
