lokar universal throttle cable
Discussion in 'Technical' started by pipman76, Aug 17, 2010.
  1. pipman76
    pipman76 Member
    alabama
    1972 mav
    has anyone used the lokar throttle cable on thier maverick and did it work well for you?i have a 70 grabber doing the v-8 swap and the throttle is a litte different than 71-up so i thought the lokar throttle would be a nice clean set-up .Let me know who ahs done this thanx alot
  2. Dave B
    I have one on my car, works fine.
  3. pipman76
    pipman76 Member
    alabama
    1972 mav
    did u purchase the 24" cable? and did u have to do any cutting to fit? is ur car a 70?
  4. Bryant
    i have one on mine. i think its the 24". i ended up puting a loop in it. i want to be able to use it if i switch to fule injection and the throttle body is in a different location. you will need to get a throttle return spring also with that cable.
  5. bmcdaniel
    I have one in my 70. Yes, you should cut it to length.
  6. Dave B
    I bought the universal one, and cut it to fit. The only thing that I did do, was take the factory retainer off the brake pedal end of the factory cable, and use it on the Lokar.
