Long tube headers...
Discussion in 'Technical' started by grabber71302, Jan 28, 2011.
  1. grabber71302
    grabber71302 Member
    alberta canada
    maverick grabber
    What brand is everyone running for long tube headers? Is it worth paying the extra money for the ceramic coating? My car is a '71 with power steering, what does the power steering drop bracket go? I can't really see where it would go..:hmmm: Has anyone got this a similar setup? I really want the long tube because they sound SO much better than short tube ones. My buddy has short tube on his V8 Ranger and they don't sound as good as they should in my opinion.
    Thanks!
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Hooker 6901. The ps drop bracket lowers the ps ram to clear the headers. Bolts to the frame where the ps ram bracket is from the factory.
  3. don graham
    Hooker 6901's here too. I have the ceramic coatings and they have worn pretty good over the years. Course it's not a street car. Not sure of the benefits for a street car. :)
  4. injectedmav
    injectedmav Member
    Georgia
    I also run the 6901's. I tack welded the bracket in place. The bolts loosened up once... only once.
  5. grabber71302
    grabber71302 Member
    alberta canada
    maverick grabber
    Thank you! I will be looking up Hookers! :drive:
  6. Bryant
    hooker 6901s ceramic coated also. cant complain. look great after 4 years.
    is your friends rangers a v8?
    does it have catalitic conveters on it still?
    if its a 6 cylinder or has cats then its not a fair comparison. i have heard plenty of shorty header cars that sounded great.
  7. grabber71302
    grabber71302 Member
    alberta canada
    maverick grabber
    he installed the v8,he removed the 2.9 v6. no,there is no cats on it....
  8. Bob Wiken
    Fayetteville, Arkansas
    check Amazon.com
    #6901HKR
    $165.00
  9. grabber71302
    grabber71302 Member
    alberta canada
    maverick grabber
    thanks Bob, I will check it out!
  10. Dave B
    I ran Hedmans for years on my 74 Grabber.
  11. tim keck
    sharps chapel,Tn
    Yep, 88300 Hedmans on mine for years, Fit well and a wee bit cheaper than the Hookers.
  12. strokermaverick
    strokermaverick Member
    The ceramic coating will help the headers last alot longer from rust out, along with the other binifits of lowered underhood heat and improved exhaust scavaging. So the extra cost, in my opinion, would be worth it.(y)
  13. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    If you decide to go coated, give Jet Hot a call.
    They are a Hooker dealer, and sell them new with their Jet Hot coating.
    It has been about 5 years since I checked, so things may have changed, but last I checked Hooker only coats the outside of the headers, Jet Hot does in and out. Also, last I checked, Jet Hot Hookers were a bit cheaper than coated headers bought straight from Hooker.
    Just a thought.
  14. injectedmav
    injectedmav Member
    Georgia
    There is definitely an advantage to coating the inside and out.
  15. 72Comet302
    72Comet302 Member
    Washington State
    1972 Comet GT
    So I was under my car changing the oil and tighting up some pan bolts. And in the proccess I discovered that one of my header down tubes was bent-in pretty bad and looks like someone punched a hole above the bend with a torch to relieve pressure. Its not a small crease its like it eather crunched against the p/s actuater arm (where the rubber boot is) or it was hammered in to make clearance. Is there anyway to findout what kind of headers these are so I don't buy the same ones when I replace them? Anyone else have this problem lol or is it just the jackas* that had the car before me?
