Look at this 8" centersection
Discussion in 'Technical' started by PeytonMaterne, Jan 9, 2005.
  1. PeytonMaterne
    PeytonMaterne Member
    I am looking at this for my pinto since I put its 3.55s in the comet. The owner claims it to be some sort of locker. I don't think it's a trac loc because the ring gear ataching bolts sit flat on the diff case(not countersunk). You can also see part of a spider through the hole. Doesn't a spool do away with the spider gears all together. Other than a shimmed up open diff, what can this be?:huh:
  2. PeytonMaterne
    Here are shots of the attaching bolts
  3. Fearmont80
    Fearmont80 Member
    Burbank,IL
    maybe aftermarket posi
  4. PeytonMaterne
    It might be, but does someone know for sure. There is something in there in the one pic with a tooth of the spider gear showing. I know there are some aftermarket units that fit inside the factory carriers. Any ideas?
  5. bmcdaniel
    Doesn't look like any posi I've seen. Hard to tell from the photos. Can you stick some axles in and give them a turn?
  6. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    I had a Ford Locker, and an aftermarket locker for a 9", and the first clue is there are no spider gears, so there is no need for the shaft through the middle. Look where the axles go, you should be able to poke a broom stick all the way through, you won't on that one. Might be some sort of Posi.
  7. PeytonMaterne
    From what information I have got off the internet, it may be a powertrax lock right. It goes in an open diff case and does use the factory side spider gears and the unit itself goes between them. Is anyone familiar with powertrax products?
  8. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    if it is .......from what i hear there a good unit you will get a little clicking on turns
  9. PeytonMaterne
    The guy that has it told me he stuck axles in it and it's definately not open. I wish he were closer, so I could check it out in person. Peyton
