looking for help with an engine build
Discussion in 'New Members Forum' started by jjl, May 26, 2014.
  1. jjl
    jjl Member
    prince albert saskatchewan
    1973 ford maverick ,2006 pontiac grand prix, 1994 cadillac deville, 1967 gmc c10(project).
    Hey guys, ive been looking around for a while at how people are building their 302's. Sadly all i can find is magazine builds where people have fuel injected 302s from 90's mustangs.
    I have looked at gt-40/gt-40p heads and different top end kits but i want to see if there are other alternatives, i want to keep my old girl carbd!. 5000-7000$ budget over the winter. Any help is appreciated!:):burnout:
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Depends on what you want to get out of it. With your budget sounds like you should be able to build a nice engine.
  3. 71gold
    what drivetrain do you have...trans, rear end, rear gear, brakes, tires?
  4. CaptainComet
    Don't use the -P heads .... the regular GT-40s are OK, but you will never get headers that will work with the later ones. The revised plug angle (that makes them work better ....) gets in the way of available headers.
    If and when I do mine over, I am looking at a 331 stroker kit.
  5. jjl
    jjl Member
    I want an engine thats making close to 350hp. im not absolutely sure what the rear end is or the gearing but i was told its a posi/locker rear end. Haha sorry i havnt really looked into it but the guy before me put 14x6 cooper cobras in front and stretched the rims in the back to 14x7s same rubber.
  6. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    I`d build a 331,they make great reliable power,& last a long time.Not only that,it is pretty easy to get 400 street hp out of them without being so radical that you can`t drive your car & enjoy it.Go to Coast High Performance & look at their rotating kits,cast crank is all you need,get some 185 alum. hds from edelbrock,canfield,AFR or trick flow w/ an edelbrock intake that will fit under your hood,650 carb,a Comp cam to match your set up,headers & your on your way.
  7. Paul Masson
    1971 Grabber
    :Welcome: from New Brunswick!
  8. Earplug
    Earplug Member
    Brighton, Colorado
    1974 Comet
    Here is an easy way to get what you are looking for.
    X302/340 HP CRATE ENGINE WITH CARB, INTAKE AND DISTRIBUTOR M-6007-X302D
    Retail Price: $5,745.00 (You save $625.00)
    $5,120.00
  9. justin90
    justin90 New Member
    maverick
    new guy here few questions
    I have a maverick im.gna start on my question is will a 80/90s 302 drop in place if not what is all needed the car has a 3.3 straight 6 auto in it now cani run gt40 engine with it as well was told headers wouldnt clear. Maybe outa the ordinary I dmt come on here much if some one could email me more details would appreciate 02r6600@gmail.com
  10. 71gold
    :Welcome:...:Handshake
