Looking for parking brakes on explorer rears
Discussion in 'General Maverick/Comet' started by 7D2 Grabber, Mar 7, 2013.
  1. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
    I believe there's a handful of people that have done the explorer 8.8 rear. Just looking for some ideas for the parking brake. Thanks
  2. Joe Dirt
    all you need is a couple of u shaped cable clamps and the stock cables will connect.
  3. 7D2 Grabber
    7D2 Grabber Member
    Like these? I did a search and found a thread but the link no longer works
  4. Joe Dirt
    correct you clamp the cable to the arm on the explorer ebrake arm coming out of the backing plate
  5. rthomas771
    You can cut the cable the same length as the Maverick's cable then thread it through your Maverick's outer shield and make a ball using the head from an allen head bolt. Drill a hole in the bolt head and thread the inter cable then silver solder them together. It will look factory when your done.
  6. Dave B
    Lokar makes universal cables, with Explorer ends.
  7. 7D2 Grabber
    7D2 Grabber Member
    Looks good
