Looking for picture of a lokar throttle cable attached to the sto k gas pedal
Discussion in 'General Maverick/Comet' started by Cruzin Illusion, Jul 29, 2015.
  1. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    I am looking for a picture of a lokar throttle cable attached to a 1972 or older gas pedal. I have received the cable but was wondering if there is any modifications required to make the cable work?
    Thank,
    Tom
  2. 71Mavrk
    71Mavrk Member
    Nevada
    I could not get the '71 to work. I used a '74. They use different mounting styles. You might be able to graft part of a '89+ Mustang pedal to the '72. I considered doing that before I found the '74.
    Micah
  3. Cruzin Illusion
    1972 Grabber
    What about build a link between the cable and the gas pedal? An oval piece of flat metal with 2 holes in it. Almost like a link in a chain.
  4. 71gold
    I did something to mine but don't remember what, it wasn't a biggy tho.
    got a pic. of what you have?
  5. maver88
    maver88 Nick Taurone
    Russellville, AR
    1972 Ford Maverick 2-door & 1996 Ford F150 4wd w/ 429ci/granny low 4spd
    I have one on mine I can take a pic of, I just stuck the end of the pedal arm in a vise and mashed it flat so it would work ill take a pic of it today and post it
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If I recall correctly, I disassembled the Lokar cable to remove the standard Clevis. This left a crimped ball on the end of the cable. I then placed the small plastic piece from the stock Maverick cable over the cable and reassembled the Lokar cable.
    71gold likes this.
  7. maver88
    Russellville, AR
    this is how I did it with the early gas pedal
  8. 71gold
    this is what I did also...:thumbs2:
  9. CaptainComet
    The early gas pedal ran up through 72. There was a design change at that point, and 73-on got the later style. The early ones were trouble waiting to happen, those crimped ends would fail. My car was stranded for three days in the mid-1990s while I searched for a good cable. Most of the ones I found were bad repair attempts. Ford used this design on several models 70-72, and then switched.
    I swore it it happened again, I was going to switch to the later style pedal. It just looks like a much better design. Food for thought ....
  10. maverick93
    maverick93 Member
    clatskanie,or
    1970 ford maverick
    I have a 70 and just heated the metal rod for the pedal with a torch and turned it 90 degrees. worked perfect.
