looking like an idiot...
Discussion in 'Technical' started by rudyska, Nov 14, 2004.
  1. rudyska
    rudyska Member
    Longmont, Colorado
    1972 Ford Maverick
    Maybe somebody can help me out with this... every time I drive my Maverick I would say the first mile or so the brakes act really weird. I let the Mav warm up for a good amount of time, but when I barely tap the brakes it will pull to one side or jerk. If I press on the brake all the way, it really jerks. I mean, it jerks so bad I look like some idiot getting whiplash. Anyone know what the heck is the problem? After driving for a few min the brake "sensitivity" ifyou will goes away and its fine. Weird. :mad: :confused:
  2. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    drum brakes right?
  3. rayzorsharp
    You need to pull the front drums off and inspect the brakes. You probably just need a good brake job. Worn strut bushings can cause this but will not usually go away after warming up. You probably have leaky wheel cylinders.
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    Also Look for leaky axle seals in the rear.
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    hmmmmm the yellow mav does this as well.....once I hit the brakes hard, then it pulls straight until it sets for a while.......when you say leaking wheel cylinder>> doe you mean leaking fluid or it air some how getting in the lines? maybe shoe adjustment?
    or maybe time for new shoes all the way around......
  6. Mercurycruizers
    Venetia, PA
    Could also be a restricted brake hose....which means, it's not releasing when you take you foot off the pedal.
  7. rayzorsharp
    The leaking wheel cylinder would be leaking fluid. You can usually tell by looking at in inside of the brake drum before you take it off. You should be able to see some dampness. If it is in fact leaking it will need to be replaced. They can be rebuilt but it's easier to just replace it with a new one since they usually only cost about 8-9 bucks apiece. In my opinion it's not worth the time it takes to put a kit in one. If they have been leaking you will also have to replace the brake shoes which have been contaminated with the fluid. The drums will also need to be turned...if they are still thick enough. If you don't know what you are doing then this needs to be left to a professional or you will always have a pulling problem. The best solution to all of this though is to get hold of a disc brake setup from a later model Mav or Comet or Granada and cure your pulling problems forever. If in fact you have to pay a professional to do your brake work it can get expensive so it would be a great time to do the disc conversion. Take this from a former brake repair professional...I managed a Midas Muffler & Brake store for three years.
  8. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    Thanks.....then its not leaking....I was/am going to address this issue when I pull the motor/tranny.
    Thanks again.
  9. GPZ1100
    GPZ1100 Professional Lurker
    Tejas
    Kawasaki 700 Prairie, Gpz1100, & Concours C14
    Quote: "[​IMG] looking like an idiot... "
    A picture would help. lol. ;)
  10. rudyska
    rudyska Member
    Longmont, Colorado
    1972 Ford Maverick
    your avatar is scary
  11. GPZ1100
    Tejas
    Gotta luv a gal with junk in tha trunk!
    Did you get your brakes fixed?
  12. rudyska
    rudyska Member
    Longmont, Colorado
    1972 Ford Maverick
    she looks like the devil. no i dont have any money to do anything and i know nothing about cars... so im ****ed till i can get some cash or somebody to do it.
  13. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Betty Page was an early queen of burlesque. You youngsters should "bone up" on your history. ;)
  14. rudyska
    rudyska Member
    Longmont, Colorado
    1972 Ford Maverick
    shes sick looking
  15. rudyska
    rudyska Member
    Longmont, Colorado
    1972 Ford Maverick
    she looks like a dude
