loose steering
Discussion in 'Technical' started by 77mav, Dec 22, 2002.
  1. 77mav
    77mav New Member
    St. Leanord Maryland
    77 Mavrick, 250, rust
    Hi, this is my first thread here. I just bought a 77 Mav, and the steering is atrociously loose. it has powersteering, front discs, and a 250 6 w/3spd auto. but yeah, how can I tighten up the steering??? I also wanna swap the bumpers, and put a 302 w/t5 in it, and the 9 inch rear with disc brakes.... but that will be later
  2. Road Warrior
    Road Warrior New Member
    Curitiba - Brazil
    76 Ford Maverick - 2.3 OHC - from Brazil
    If you wanna change the engine, dont forget the shocks (koni shocks is a good choice) and better tires too... a 302 with a T5 will go very fast !
  3. 77mav
    77mav New Member
    yeah, i know, i wanna go with bilstein monotube gas shocks (inverted). my last car handled really well, so if this one drives like a boat i am gonna cry
  4. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    kyb is my favorite shock.
  5. Mavrick newb
    Mavrick newb 20 Year old Mavrick fan
    Central Point, OR
    1973 Mav 351w 76 Mav 302
    I thought my steering was really lose but it turned out to be loose wheel bearings. Check and make sure the nut that holds the bearings in (ya im a retard that cant think of its name) is torqed down properly (cant remember how many pounds off top of my head right now). Anyways cleared my loose steering problem right up.
  6. jeremy
    jeremy I build t5's
    Corona, Ca
    My steering is hella loose--is the idler arm/pitman arm, center link bushings. Likely yours could be bad also.
