Low Compression Pressures
Discussion in 'Technical' started by Mlover, Jul 5, 2014.
  1. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    I recently bought a 74 Maverick. After checking the compression pressures the first two were 0's, and the third was barley a 40. Does this mean I need to do an engine swap? It is a v6 and it turns over but does not start.
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    You mean a V8. Either do a swap or overhaul the engine you have. You got bad head gaskets and rings. It's worth rebuilding.
  3. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    Would you happen to know where I could get it rebuilt for a fair price? I live in Southern California.
  4. jtown77
    jtown77 Member
    Arizona
    71 Comet
    Northern Auto Parts. You have to know what year, which engine. Then you will need to know what size pistons, .020, .030 etc...
    Good luck
  5. 71gold
    or a straight 6...:huh:
  6. Bryant
    where in so cal?
    i have several engine machine shops i use depending on the intended use.
  7. Mlover
    Mlover Member
    Bay Area
    Ford Maverick 1974
    In the Inland Empire area, I have the intention to rebuild the whole engine. it is a 250 straight 6.
  8. Bryant
    thats a little far from my area. im sure their are some good machine shops around you.
  9. 71gold
    this could mean you have some stuck valves. I had one in a 250 mav I bought. I pulled the valve cover and tapped them all with a mallet (hammer). it broke loose and I went to driving...
