Lower Control Arm Bolts
Discussion in 'General Maverick/Comet' started by lilfarley, Nov 16, 2008.
  1. lilfarley
    lilfarley Chris Comley
    Central City, Iowa
    Does anyone know what to torque them to I just got some and they for some reason didn't come with instructions that list torque specs. also got many other goodies but won't be able to put them on until this winter.
    Goodies list: Moog Upper Ball Joints,Partsmaster Lower Control Arms and Ball Joints, Brake Best Rear Brake Cylinders, Brake Best Rear Brake Shoes, And Monroe Gas Charged Rear Shocks. This is most of the Car Parts I will be getting for Christmas the only reason I know this is because my dad asked me where the best places to get them would be.:dance:
  2. Jamie Miles
    If there is a torque setting for those bolts, I didn't know it when I installed mine. I just torqued mine until they were good and tight, which boils down to about as tight as I could possibly get them with a 1/2 inch drive Craftsman socket wrench. The shop that did the front end alignment on the car shortly after loosened them back up anyways to properly adjust camber, so I guess it didn't matter much.
  3. lilfarley
    Central City, Iowa
    Reason I ask is because there is a baggie with some hardware and stuff and it say that the included instructions state specific torque specs and the upper ones have specific ones on the instructions included.
  4. |MaverickMat|
    |MaverickMat| '74 Grabber
    Portland, OR
    1974 Grabber
    Same here. I just applied He-Man strength to mine using a massive wrench.
  5. rthomas771
    75-100 ft lbs on the lower control arm...ball joint stud gets 60-90 ft lbs.
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    went to get the specs out of my manual :D and here they are :D
    :Handshake
  7. 71gold
    if a TQ.wrench has to be calibrated to make sure it is reading correctly...
    then why do they give you a...
    TQ. spec. that has a 25% error margin?...75-100 ft. lbs.
    or...30%... 60-90 ft. lbs.
    why would it not be...80 ft. or 75 ft. lbs. an exact # for a calibrated wrench. :hmmm:
    some people have told me...they pick a # from the 75-100 that they feel comfortable with...you could do this with any hand wrench...
    some thighten bolts with...open hand or 2 fingers or use 1/4" drive sockets... as not to strip the threads...
    ...:huh:...
  8. rthomas771
    Good question... I was told years ago if the bolt/nut is brand new the toque it down to the high end of the scale, say 95 foot pounds instead of 100...if using used fasteners then stay at the low end of the scale.
  9. 71gold
    ...my rule-of-thumb...
    tighten untill it breaks...back up 1/4 turn...:yup:
    ...:rolleyes:...
  10. lilfarley
    Central City, Iowa
    So 95 on the control arm bolt
    and 85 on the ball joint nut
  11. CaptainComet
    My wife had a 96 Monte Carlo and I did the brakes on it. The manual called for the caliper bolts to be in at 150 foot lbs! ... and I don't have air tools (yet).
    1/2 inch breaker bar with a 4 foot extension ... I was doing pullups on the bar to break them loose ... git'r'done ...:thumbs2:
  12. 71gold
    "75-100 ft lbs on the lower control arm...ball joint stud gets 60-90 ft lbs"
    ...:Handshake....
  13. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    I have a 2-door '71 Maverick with a 4.1L, 250ci, I6 with A/C. There are two different sizes of lower control arm bushings offered for my year from moog. Does anyone know which size is the one I need for my car? The choices are 1-9/16" and 1-7/16." any help you could offer would be great. thnx.
  14. jgmerrill
    jgmerrill New Member
    Tennessee
    1975 Ford Maverick 4dr 250ci c4
    :biglaugh: i like it. lol
  15. bmcdaniel
    The low end is the minimum required to begin to stretch a fastener of a given size, the high end is the not-to-exceed value to keep from over-stretching the fastener. Different size/composition fasteners have different ranges.
